Scale setup
2982
01-27-2014 03:48 AM
ShaningYu
Honored Contributor
I want to publish a map service with the scale with the maximum scale 1:500 or 1:1000.  I did the setup in ArcMap.  However, when I tried to publish it as a service, I got a High Severity Error in the Service Editor: Analyze:  Code 00014 Annotation layer does not draw in table of contents order.  How can this be solved?  Thanks.
ShaningYu
Honored Contributor
I tested j.quinn's approach but the error exists.  However, I re-created a mxd and got the map service published.  For whatever reason, this problem was gone.
By the way, in my re-created one, the Annotation Groups: Default is on.
Thanks to j.quinn's response.
ShaningYu
Honored Contributor
Referring to ESRI Help topic:
http://resources.arcgis.com/en/help/main/10.1/index.html#//00sq00000027000000
Still unsolved.  Hopefully, someone can hint me how to solve this problem.
JonathanQuinn
Esri Notable Contributor
Do you actually have annotation in your map?  You can try to turn of the Default group layer for annotation.  Go to View > Data Frame Properties > Annotation groups and uncheck the Default group.
ShaningYu
Honored Contributor
