restrict webadaptor services directory access
8251
12
05-21-2015 10:17 AM
DuarteCarreira
Is there a way to have the services directory accessible through port 6080, and not through the webadaptor?
As far as I can see we can only disable all access. This doesn't make much sense to me... it would be useful to have access "internally" and block "external" access.
Duarte
DuarteCarreira
Hi Rebbeca. I had already tried that option. The problema is you don’t see the layers list, fields, etc. like you do in the rest directory service. At least I couldn’t find a way to get this info.
The rest dir is most useful for us while developing our webapps. Without it we are flying blind…
De: Rebecca Strauch
Enviada: terça-feira, 26 de Maio de 2015 16:46
Para: Duarte Carreira
Assunto: Re: - restrict webadaptor services directory access
GeoNet <http://jiveon.jivesoftware.com/mpss/c/mAA/PDcDAA/t.1nc/q7uqwW_HSkaYQGAj6aWV0g/h0/WXYIqorVIGQuIDJ2G2ju5AEeIPykSY57g2VIWA8pAkF2-2BlveMrdQT1t2nJlEgcli>
reply from Rebecca Strauch<http://jiveon.jivesoftware.com/mpss/c/mAA/PDcDAA/t.1nc/q7uqwW_HSkaYQGAj6aWV0g/h1/WXYIqorVIGQuIDJ2G2ju5Cq78MLQmxOA6AjDKPN5-2B-2BTzsfUHV3Jhvjd7G1Djg26BqvFrRvVo1Cfqsi3ajEIRDg-3D-3D> in ArcGIS for Server - View the full discussion<http://jiveon.jivesoftware.com/mpss/c/mAA/PDcDAA/t.1nc/q7uqwW_HSkaYQGAj6aWV0g/h2/WXYIqorVIGQuIDJ2G2ju5BgYGKlxCJXzUFxsSjPkR7gsMkrFqlzxzkcUrAQ-2BL2oVgA2hfhgsl1GN41AmxTupifIvjsJPKICYcVBq7UM1AME-3D>
RebeccaStrauch__GISP
yes, I would agree that is still a problem.
Did you promote the idea yet?  Looks like there is still only 90 points....getting this voted up may be our best best to get this added to future releases anyway.
https://c.na9.visual.force.com/apex/ideaView?id=087E00000005ArlIAE ​  if logged in
ArcGIS Idea - Disable REST Services Directory through Web Adaptor   if not.
I had posted this above....but never hurts to do it again so others may see it.
DuarteCarreira
Reporting back... no luck... I could only block the entire rest access. That's even worse...
So back to disabling the rest directory only for webadaptor and leaving it on for "direct" access through port 6080. esri please hear us...
I already voted the idea up... but the ratio of ideas that get implemented really does not motivate voting...
Rebecca I'l mark your answer as correct: no is the answer...
