Restrict Cores/Ram used by ArcGIS Server
1121
06-25-2024 07:22 AM
SimonSchütte_ct
MVP Regular Contributor
Sometimes you want to run ArcGIS Server (4 Core License) on a machine with more than four cores (maybe you only have a single machine deployment or other Software installed on the server). The additional cores are not needed/intended for ArcGIS Server.
Is there a way, similar to the one available for Geoanalytics Server, to limit CPU Cores and RAM to be consumed by ArcGIS Server? I did not find anything documented. Do the mentioned parameters work by any change on ArcGIS Server as well?
  • percentageMaxAllowedComputeCores—This represents the maximum CPU cores (as a percentage of total available on a machine) that will be used by the compute platform worker process on a single node. If the specified value translates to less than one CPU core, one CPU core will be used for the compute platform worker process.
  • percentageMaxAllowedComputeMemory—This represents the maximum memory (as a percentage of total available memory on a machine) that will be used by the compute platform worker process on single node.
GeoAnalytics Server settings—ArcGIS GeoAnalytics Server | Documentation for ArcGIS Enterprise
"In the past, people have used “Windows System Resource Manager” to do this. But, the Windows Server 2012 documentation says “Windows System Resource Manager (WSRM) is deprecated."Limiting CPU Cores on Windows Server 2012 - Esri Community
There is the https://www.esri.com/content/dam/esrisites/en-us/media/technical-papers/licensing-arcgis-enterprise-... paper regarding virtual cores, but many machines have a 1:1 core equivalency.
Relates to ArcGIS for Server License - Limit number of cores - Esri Community and ArcGIS Server and CPU cores - Esri Community ...
David_McRitchie
Hey Simon,
For this I would go into the Task Manager >  Details and find the process for ArcGIS Server.
Right click and hit properties > Set Affinity and here you can select the CPU Cores that will be used against this process.
Hope that helps,
David
Esri UK -Technical Support Analyst
SimonSchütte_ct
Hi, thank you. However, affinity settings revert to default after a restart. I found it possible to create a shortcut like this:
cmd.exe /c start "software" /High /affinity hexadecimalvalueforcores  "path"
But the ArcGIS Server Processes autostart.
Is there a way to add execution parameters for ArcGIS\Server\framework\runtime\ArcGIS\bin\ArcSOC.exe and ArcGIS\Server\framework\etc\service\bin\ArcGISServer.exe to permanently assign the affinity even after reboot?
JoshuaBixby
MVP Esteemed Contributor
Regarding your first question about ArcSOC.exe, you won't need to do anything for that process if you address the ArcGISServer.exe process because CPU affinity is inherited by child or spawned processes.
SimonSchütte_ct
Thanks!  This still leaves the question on how to make the affinity setting stick even after reboot and the question on how to restrict the memory. I could not find an affinity equivalent for the memory...
