Resolving 001488 Error Geoprocessing Service
1047
09-17-2017 12:20 PM
MeleKoneya
I am using the Shortest Route Service Geoprocessing example in the tutorial data. I have changed it to use local data and routing works in ArcMap. When I try to publish it as a GeoProcessing Server, it fails and tells me that I am using data that is not registered with the server. We have disabled the ability to copy data to the server so how do I resolve this issue?
I cannot tell what needs to be registered with the Server to proceed.     I have reviewed the following article but it is lacking in details to assist with what I need to register
http://support.esri.com/technical-article/000012592
Let me know if you have faced a similar issue and how you resolved it.
Mele
