Removal of ArcMap-based runtime from ArcGIS Server
1680
09-19-2022 05:59 PM
MarkChilcott
Hi Peoples,
At the ArcGIS Server 10.9.1 release, one can disable the ArcMap-based runtime.
According to this article: Removal of ArcMap-based runtime from ArcGIS Enterprise
The removal of the ArcMap-based runtime for ArcGIS Enterprise will affect you if you have ArcGIS Server services leveraging the ArcMap-based runtime. This includes workflows that publish from ArcMap and/or consume services that were originally published from ArcMap.
This suggests ArcMap cannot consume the services.  I would have thought with REST it would be possible?  Does this also include basemap services?
Cheers,
Mark
ChristopherCounsell
MVP Frequent Contributor
ArcMap can continue to consume the services after you migrate them to ArcGIS Pro service runtime.
https://enterprise.arcgis.com/en/server/10.9.1/publish-services/windows/migrating-services-to-the-ar...
The comment is likely referring to services/workflows that explicitly run on the ArcMap runtime. e.g. services that are not compatible, such as map services with a server object extension (SOE) or server object interceptor (SOI). If you've built dependency on the ArcMap runtime you'll need to stay on it or upgrade the workflows/dependencies.
Please don't forget the kudos 🙂
ChristopherCounsell
ChristopherCounsell
