"Generate" operation (https://[root]/content/features/generate) is distorting features
1527
10-10-2024 09:28 PM
DavidHorsey
**CROSS-POST** I originaly posted this in the Dev community, but I think it also belongs here.
I've created a single shape (wkid: 102100) with 4 vertices in a shapefile.
When I run that shapefile through an analyze operation on my local Portal machine, I get the following response:
    "publishParameters": {
        "type": "shape",
        "name": "cadastre_wgs84wm_digitised",
        "sourceUrl": "",
        "maxRecordCount": -1,
        "targetSR": {
            "wkid": 102100,
            "latestWkid": 3857
        "editorTrackingInfo": {
            "enableEditorTracking": false,
            "enableOwnershipAccessControl": false,
            "allowOthersToUpdate": true,
            "allowOthersToDelete": false
        "layerInfo": {
            "currentVersion": 11.1,
            "id": 0,
            "type": "Feature Layer",
            "displayField": "",
            "description": "",
            "copyrightText": "",
            "defaultVisibility": true,
            "editFieldsInfo": null,
            "relationships": [],
            "isDataVersioned": false,
            "supportsRollbackOnFailureParameter": true,
            "supportsAdvancedQueries": true,
            "supportsValidateSQL": true,
            "supportsCalculate": true,
            "advancedQueryCapabilities": {
                "supportsReturningQueryExtent": true,
                "supportsStatistics": true,
                "supportsDistinct": true,
                "supportsPagination": true,
                "supportsOrderBy": true,
                "supportsQueryWithDistance": true
            "geometryType": "esriGeometryPolygon",
            "drawingInfo": {
                "renderer": {
                    "type": "simple",
                    "symbol": {
                        "type": "esriSFS",
                        "style": "esriSFSSolid",
                        "color": [
                            202,
                            252,
                            208,
                            255
                        "outline": {
                            "type": "esriSLS",
                            "style": "esriSLSSolid",
                            "color": [
                                110,
                                110,
                                110,
                                255
                            "width": 0.4
                    "label": "",
                    "description": ""
            "hasM": false,
            "hasZ": false,
            "allowGeometryUpdates": true,
            "hasAttachments": false,
            "htmlPopupType": "esriServerHTMLPopupTypeNone",
            "supportsApplyEditsWithGlobalIds": true,
            "objectIdField": "FID",
            "globalIdField": "",
            "typeIdField": "",
            "fields": [
                    "name": "FID",
                    "type": "esriFieldTypeOID",
                    "alias": "FID"
                    "name": "Id",
                    "type": "esriFieldTypeInteger",
                    "alias": "Id"
            "types": [],
            "templates": [
                    "name": "New Feature",
                    "description": "",
                    "drawingTool": "esriFeatureEditToolPolygon",
                    "prototype": {
                        "attributes": {
                            "Id": null
            "useStandardizedQueries": true,
            "enableZDefaults": false,
            "zDefault": 0,
            "supportedQueryFormats": "JSON",
            "hasStaticData": false,
            "capabilities": "Create,Delete,Query,Update,Editing",
            "supportsCoordinatesQuantization": false,
            "supportsAttachmentsByUploadId": true,
            "minScale": 0,
            "maxScale": 0,
            "extent": {
                "xmin": 12895760.54079283,
                "ymin": -3755035.285140656,
                "xmax": 12895774.872848857,
                "ymax": -3754980.687832646,
                "spatialReference": {
                    "wkid": 102100,
                    "latestWkid": 3857
    "records": [
            "attributes": {
                "FID": 0,
                "Id": 0
    "fileSize": 3018
I subsequently run the same shapefile through a generate operation, with the publishedParameters from the response to the analyze operation. That gives the following output:
    "featureCollection": {
        "layers": [
                "layerDefinition": {
                    "id": 0,
                    "displayField": "",
                    "description": "",
                    "drawingInfo": {
                        "renderer": {
                            "type": "simple",
                            "symbol": {
                                "type": "esriSFS",
                                "color": [
                                    206,
                                    210,
                                    242,
                                    255
                                "outline": {
                                    "type": "esriSLS",
                                    "color": [
                                        110,
                                        110,
                                        110,
                                        255
                                    "width": 0.4
                            "label": "",
                            "description": ""
                    "hasM": false,
                    "hasZ": false,
                    "typeIdField": "",
                    "types": [],
                    "templates": [
                            "description": "",
                            "prototype": {
                                "attributes": {
                                    "Id": null
                    "zDefault": 0,
                    "fields": [
                            "name": "FID",
                            "alias": "FID"
                            "name": "Id",
                            "alias": "Id"
                    "minScale": 0,
                    "maxScale": 0,
                    "extent": {
                            "wkid": 102100,
                            "latestWkid": 3857
                "featureSet": {
                        "wkid": 102100,
                        "latestWkid": 3857
                    "features": [
                            "attributes": {
                                "FID": 0,
                                "Id": 0
                            "geometry": {
                                "rings": [
                                            12895760.665251553,
                                            -3754980.687832646
                                            12895774.872848857,
                                            -3754980.7207584456
                                            12895774.751507085,
                                            -3755035.285140656
                                            12895760.54079283,
                                            -3755035.2522147074
                                            12895760.665251553,
                                            -3754980.687832646
                                    "wkid": 102100,
                                    "latestWkid": 3857
        "showLegend": true
This results in a shape with 5 vertices.
"features": [
					"attributes": {
						"FID": 0,
						"Id": 0
					"geometry": {
						"rings": [
									12895760.665251553,
									-3754980.687832646
									12895774.872848857,
									-3754980.7207584456
									12895774.751507085,
									-3755035.285140656
									12895760.54079283,
									-3755035.2522147074
									12895760.665251553,
									-3754980.687832646
							"wkid": 102100,
							"latestWkid": 3857
Can anyone tell me why my input shape with 4 vertices has been distorted in such a way that it now has 5 vertices? Throughout these operations the spatial references have, to my knowledge, all been set to WKID: 102100, so I don't beleive any transformations (should) have been applied to the data.
Any help understanding what is happening here would be appreciated.
Thanks!
berniejconnors
@DavidHorsey If you look at the coordinates the first point and the last point are the same.  When a polygon is represented in JSON it is called a "ring".  It's not a ring or closed polygon unless the first point and the last point are the same.  If the fifth point were ommitted from the JSON it would be just a line with a start point, 2 vertices and an end point.
Cheers,
Bernie.
berniejconnors
Cheers,
Bernie.
DavidHorsey
Thanks @berniejconnors. That answers my question, but not my problem 😂 I have a legitimate problem where shapefiles uploaded to an application are getting slightly distorted. I was manually working through the process, e.g. using the analyze and generate operations and checking the results, when I came across the situation above and thought this was the root of my problems.
Thanks for taking the time to answer my question, at least I've learnt JSON rspresentations of shapes have n+1 vertices.  I'll keep working through my issue and, depending on what I find out, might lean on the community for more help. Watch this space...😀
berniejconnors
If you are seeing slight distortions it could be a reprojection of your data.  What is the map projection of your shapefiles?  If it is not web mercator your shape files are likely being reprojected to match the map projection of your basemap. The AGOL basemaps use the web mercator projection.
Bernie.
