question mark next to the data store
1656
04-04-2013 07:15 AM
ElizabethNolan
We upgraded to 10.1 and are setting up the server. I configured a data store using a unc path. I can access the path etc., and the server mananger account that is being used has full righs to the unc path. Any ideas why there is a question mark next to the data store? I looked over the documentation and it doesn't touch on statuses and their meanings.
I am at a loss on this one.
Beth
ErinBrimhall
Hi Elizabeth,
I assume you are using the "ArcGIS Server Manager" website to administer ArcGIS Server?
The yellow question mark next to a datastore is simply an indication that the validity of the datastore has not been determined since the last time you navigated to the Data Store page.
If you click the "Validate All" button above the list of data stores you should see those yellow question marks change to green checkmarks (unless there is something wrong with the way one or more of the data stores is configured).
Hope that helps!
