Python from ArcGIS Server 10.9.1
2729
07-18-2022 12:03 PM
tempRodrigo_DaSilva
Hey everyone,
I don't know if this is the correct channel...
I'm having a problem installing a custom library to Python from ArcGIS Server.
Environmental considerations:
  • Linux Operating System
  • ArcGIS Enterprise 10.9.1 (was migrated from 10.8.1 recently)
  • Library that will be installed: ReportLab v.2.7
    Error print: https://prnt.sc/smYeib7kQ7JL
Reference documentation: https://enterprise.arcgis.com/en/server/latest/publish-services/linux/deploying-custom-python-packag...
" Start the wine explorer application. At the terminal, paste this command:
. <ArcGISServer_InstallDir>/arcgis/server/framework/etc/arcenv; wine explorer & "
Best Regards,
2 Solutions
ElizabethLorenaRodriguez
Hello @tempRodrigo_DaSilva
I think the problem is related with the runtime for ArcGIS Server. In version 10.9.1 ArcGIS only uses Python 3.0, but you can add the runtime in the installation process:
https://enterprise.arcgis.com/en/server/latest/administer/windows/disable-arcmap-runtime.htm
You can enable ArcMap Runtime Support and install Python 2.x by following the steps above to modify an installation and enabling the ArcMap Runtime Support feature.
You can also enable ArcMap Runtime Support and install Python 2.x using the ADDLOCAL command line parameter:
  • ADDLOCAL=<optional features to install>
    Use the ArcMap property to enable ArcMap Runtime Support.
setup.exe /qb ADDLOCAL=ArcMap
tempRodrigo_DaSilva
Hi @ElizabethLorenaRodriguez
Thanks for your contribution
Although some time has passed, I saw your answer and the insight to solve my problem.
Best regards,
