Publishing Tables Bug: Data/Field Musical Chairs
1022
11-28-2013 04:56 AM
AndrewBlakey
Hello all:
I'm getting a really weird bug that I can't resolve and am looking for any help/advice.
The problem is that I have a published MapService with 3 tables and 1 Feature Class. The 3 tables are named properly but all contain the wrong fields and I suspect the wrong data. I got here in this order:
  1. 3 Tables and 1 Feature Class in my AWS SDE Database "geodata"
  2. All data loaded into an MXD and published
  3. Publish occured without any data transfer. "geodata.sde" is properly linked in Server Manager
  4. Visit tables in REST interface and notice the problems.
  5. A simple QUERY in the REST interface returned data sporadically and from the wrong table.
  • The table data, if accessed in ArcMap (not through the map service, but through the database), are all perfectly fine.
  • All data is set as Versioned but only 1 version exists
Please see attached image for a visual description of what's wrong here.
Any ideas?
KimPeter
Hi Andrew,
It would be best if you contacted support so they could walk through the steps you're taking and ask the right questions.  There're really more questions/variables here than can be addressed in a forum post.
Plus, if there is a bug in the software, support can log it and contact the correct people in development to work on fixing it. 🙂
