Published geoprocessing tool does not initializeParameters
1330
03-10-2020 08:43 AM
AndreasFrid
Hi all!
I have developed a geoprocessing tool that works as expected within ArcGIS Pro 2.5.
The tool is quite simple, it loads three values from the database into three different parameter boxes with validation & initialize parameters.
These parameters are then possible to modify and the new values are saved to the same table as the tool gets executed.
The next run the tool will get the new parameters within the textboxes.
But the problem is when the tool gets published to our Portal. (10.8.x)
The parameters does not load from the database, it uses the default values from when the tool was published the first time. I haven't seen anywhere that the portal should not support the initialize parameters function, so am i doing anything wrong here?
Kind Regards
Andreas
