Proxy and firewall
1400
02-04-2020 10:24 AM
SoratoSouza_e_Silva
I would like to use an application firewall in security mode, to protect Arcgis Enterprise, can this be done?
The intention is to install a reverse proxy.
There is a documentation?
Thank´s
BenTurrell
Hey Sorato Marques‌,
You can definitely use a firewall to protect your enterprise build. Here is some information on what ports you need open to allow it to work for ArcGIS Server:
ArcGIS Server 10.7.x system requirements—ArcGIS Enterprise system requirements | Documentation for A...
And here are the ports for Portal:
Portal for ArcGIS 10.7.x system requirements—ArcGIS Enterprise system requirements | Documentation f...
Ben
If this answer has helpful please mark it as helpful. If this answer solved your question please mark it as the answer to help others who have the same question.
BenTurrell
Ben
