Problems with Operation Dashboard for Portal 10.6.1
1930
12-20-2018 01:29 AM
SunbeamRahman1
Hello everyone.
I have Enterprise 10.6.1 standard installed inside two separate vbox machine, one with Server and another with Portal. Both has working Web Adapter and federated. All patches are installed. The problem is I cannot seem to get Operation Dashboard to create a map which interacts with other widgets.
First the Layer Action of map doesn't work with select filter activated. Then randomly crashes when trying to view table. Moreover the widgets only seem to appear when using Map Image Layer, keeps loading with Hosted Feature Layer. I tried publishing with Desktop and Pro, enabling query.
SunbeamRahman1
Update: I just tried the same license with Builder to create a single machine installation, and the same map creates dashboard with no problem.
Update 2: Also tried this, says 'Layer does not meet the necessary criteria to be used for this visual element.'
