PrintingTools (GP server) Export Web Map Task -> execute fails - 403 error
1530
05-15-2013 12:00 PM
EtienneAraya
Hi
I want to disable Services Directory to anyone to avoid inspect the urls.
When I disable "Services Directory" on AGS 10.1 SP1 when I try to print it send a error 403
How can avoid that or resolve?
<AGS URL>/rest/directories/arcgisoutput/Utilities/PrintingTools_GPServer/_ags_11cf55205c1146dc8cd7908b0516a0c7.pdf
Error: Services Directory has been disabled.
Code: 403
Thank's
Etienne.-
StevenMoore1
This issue has been logged as the following bug:
[ NIM087900 - Cannot access feature service attachments or PDF file output from output directory when Services Directory access is disabled. ]
It is fixed at 10.2
PeterYoon
Hi support
Can you please explain how this problem is fixed in version 10.2?
I have a similar problem. When I disabled the services directory, the user (this is a public facing site ) is unable to download extracted data. However, if the services directory is enabled, extracted data can be saved in the user's computer. Thanks
Pete
NidhinKarthikeyan
Honored Contributor
