Portal don´t start in Ubuntu
1040
02-05-2020 12:17 PM
SoratoSouza_e_Silva
I have installed Portal for arcgis on ubuntu, but after completing the installation the portal does not appear. I already started
the service but it doesn't work, I see that port 7443 is not listen
Can someone help me?
Thank´s
Tags (1)
BenTurrell
Hey Sorato Marques‌,
Have you completed the post install steps listed here?
Installing Portal for ArcGIS—Portal for ArcGIS (Linux) Installation Guide | ArcGIS Enterprise
That will cover off starting the service when the machine is rebooted. If you are manually starting the service can you try out:
systemctl status arcgisportal.service
And let us know what the output is?
Otherwise you could try
journalctl -u service-name.service
Ben
If this answer has helpful please mark it as helpful. If this answer solved your question please mark it as the answer to help others who have the same question.
SoratoSouza_e_Silva
Hi, Ben Turrell‌,
Thank´s for your attention
below follows my output:
The portal in not active unfortunately. Can you help me?
BenTurrell
Sorato Marques‌,
Have you done the post install steps?
You need to copy the arcgisportal.service file to the /etc/systemd/system folder and create the system link.
Ben
SoratoSouza_e_Silva
Thank´s
