Performance: Desktop\Server and file\SDE Geodatabase,
729
06-13-2013 10:34 AM
JamalNUMAN
Legendary Contributor
I think that the only way to have a reasonable speed for the web mapping application (ADF, Silverlight, Flex) is to cache the map. Otherwise, it is really slow
1. For example, the mxd file is much faster than its service.
2. If the workflow includes SDE goedatabase then this is much slower the file geodatabase
Slow = F(Server, SDE)???F: is a function of
But what if cashing a map is like a nightmare? Never succeed! It ends with ???the generation is not in progress???
[ATTACH=CONFIG]25251[/ATTACH]
Thank you
Best
Jamal
Jamal Numan
