Overwrite Map Service Does Not Seem to Work Properly
2639
05-31-2013 12:00 PM
by Anonymous User
Not applicable
especially when attempting to overwrite map service. Initial Map Services publish just fine. However the overwrite locks up or hangs ArcMap and then, after forcing a close of ArcMap and re-start of the service in ArcCatalog/Manager, the update apparently has taken place. Has anyone else experienced this? Yes, I have examined the logs and about the only thing I can find is:
"......failed to rename cache folder..."
Thanks in advance,
RGibson
JeffJacobson
I was just researching this issue and found another thread on this.
http://forums.arcgis.com/threads/83235-Overwrite-Existing-Map-Service-hangs?highlight=overwrite
