Offline Webmap and Creator User Type
879
10-16-2025 03:03 AM
Y_Chau
I noticed that with Creator User Type I cannot open the webmaps that have offline enabled. Can someone help me understand?
Sincerely
YC
Eugene_Adkins
Check your permissions and sharing levels for the webmaps you're referencing. There's nothing about a "creator" user type that should prevent someone from accessing a webmap that is offline enabled.
Priya_Das
Hi @Y_Chau
The Creator user type can access offline-enabled web maps but only if the map and its layers are properly configured for offline use. The issue is likely with the map’s settings, not the user type.
  • Check each layer in the web map, Ensure sync is enabled for feature layers, Confirm tile layers allow export
  • Review sharing settings
Y_Chau
Hi @Priya_Das
I am baffled by this behavior and completely clueless why this happens. One user in our organisation is not able to view one vector basemap.
  • They can view all raster basemaps published by me and shared with groups of which this user is a member.
  • They can also view another vector basemap published by another user and shared with Everyone.
  • If I publish a webmap with this particular basemap, this user again cannot open them in web or in Field Maps. I even tried sharing this basemap with Everyone!
What sharing settings could have triggered such access restrictions?
YC
