Migrating Server 10.1 to 10.2.1
1583
01-10-2014 11:43 AM
IB1
I'm about to upgrade from Server 10.1 to 10.2.1 and have a question.
I currently have (2) active two-way replicas.
I believe the servers hosting the other data are either 10.1 or 10.2.
When I upgrade to 10.2.1 will this cause any problems with the two-way replicas?
Thanks!
NidhinKarthikeyan
Honored Contributor
The child replica geodatabase must be the same geodatabase release as or a later release than the parent replica geodatabase. If you upgrade the parent replica's geodatabase, you also must upgrade the child replica's geodatabase before synchronizing.
You can take a look at the following weblink:
Replication and geodatabase releases.
http://resources.arcgis.com/en/help/main/10.2/index.html#//003n000000z3000000
IB1
Somebody.... anybody?
NidhinKarthikeyan
Honored Contributor
