Migrating feature class layers from ArcMap Geodatabase to ArcGIS Enterprise Database question
1145
5
08-18-2025 08:28 AM
SharonBogner
Is it possible to migrate feature class layers from an ArcMap Geodatabase to an ArcGIS Enterprise Database and preserve true arcs? We’re in the process of migrating to ArcPro and the process we’re using is exploding all the arcs into a dozen or so small line segments. This is not only frustrating for the users but also requires far more database storage space. Thank you for your help and advice.
George_Thompson
Esri Notable Contributor
Can you provide some more details, like:
  • What is the ArcMap geodatabase: file / enterprise / other
  • What is the RDBMS to be used in the Enterprise database?
    • This will be an Enterprise Geodatabase (EGDB), correct?
  • What is the version of ArcMap and Pro being used?
  • Are you just copying the lines with true curves into the new EGDB?
--- George T.
SharonBogner
Hi George,
We're migrating file geodatabase layers from ArcGIS Desktop 10.8.2 to Enterprise geodatabase. We're running ArcGIS Pro 3.5.1. The layers contain lines or polygons drawn with lines and arcs. The layers are being packaged and then sent to the GIS dept for integration into the Enterprise geodatabase. I am not in the IT Dept. I'm one of the users; so I can't give any more info than that. I suspect that packaging the layers is what is causing the change to the data. Is there a way to move the layers from my file geodatabase into the Enterprise geodatabase without loss of the true arcs? Thank you.
MichaelVolz
Esteemed Contributor
Sharon:
Can you provide more detail on your process from migrating from a file gdb(s) to an enterprise gdb for your data, as this process should not cause you to lose true arcs that you spent time to generate?
What specific tools are you using for this process?
RhettZufelt
MVP Notable Contributor
Sounds like you are just trying to create/move a copy of the data to a different location so shouldn't need to package anything.
You should be able to use the Catalog pane in Pro.  Connect to the FGDB and select the feature class(es) you want to transfer and select "copy", open the Enterprise connection and choose 'Paste'.
This should copy the data over and preserve the true arcs, etc. (at least with previous versions. I have not downgraded to 3.5 yet)
R_
MichaelVolz
Why do you believe true arcs are not being preserved?
