Migrate an ArcGIS Enterprise deployment from WIndows to Linux
1598
11-29-2021 09:20 PM
NicolasGIS
Honored Contributor
Hello,
Following my question about webgisdr OS agnostic (https://community.esri.com/t5/arcgis-enterprise-questions/will-webgisdr-backup-someday-be-os-agnosti...) which did not bring much attention, I am looking for a workflow to migrate an existing ArcGIS Enteprise WIndows based to Linux.
Is it doable ?
Thanks !
Nicolas
Tags (1)
MichaelGinzburg
https://community.esri.com/t5/arcgis-enterprise-questions/migration-arcgis-server-from-windows-to-li...
@JonathanQuinn wrote:
There is no out of the box way to migrate from Windows to Linux. If you have the original MXD's or SD files, you can loop through them with Python and the arcpy module to republish them. You can also loop through your arcgisinput folder to find the MXD's to republish. You'll need to republish manually or via scripting.
Scott_Tansley
MVP Regular Contributor
I've never heard of this being achieved, but "theoretically" you could consider the use of:
https://www.esri.com/arcgis-blog/products/arcgis-enterprise/administration/moving-content-across-tie...
I have very limited experience of using Linux, so this is a guess but may be worth considering?
Scott Tansley
https://www.linkedin.com/in/scotttansley/
OfraAi
Hello,
Is there anything new about the possibility to migrate from Windows to Linux? version 11.3
Thanks
Ofra
