map slow after zoom and pan map
3246
09-02-2014 09:55 PM
JulieBiju
Advance thanks to all I developed a website using  ArcGIS 10 Desktop  which is wrking fine. Nw the problem is each time zooming and pan the map will take 10-12 seconds time to load map in my map application. Y it is taking too much time. Map data is in  ArcGIS server 10.1. Server having 24 GB RAM and and server 2008R2 machine. when I checked tutorial in http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#CustomZoomBox , It is very faster and not even taking  1 sec to load the map. what is the problem in my case? I want the same way  view of map in my application. Can anybody help me to solve the issue?
AndyOmmen
Hello Julie,
Have you looked at the Silverlight API help section for navigating maps: ArcGIS API 3.1 for Silverlight ? Also, I would try building a map cache which you can get help with at: ArcGIS Help 10.1 I hope this helps.
