map service doesn't refresh raster that change every 5 minutes
2920
09-03-2014 08:44 AM
enricobonansea
In ArcGIS server  10.2  we experienced this problem:
- we have  a mxd  that contains a weather radar image (tiff) that change in rear real time (5 to 10 minutes)
- the image is managed by a raster catalog
- raster image is on a storage area network   registered in Arcgis server : The tiff file is overwritten by a script every 5 minutes.
- this mxd is shared like a map service
The service is running but while the tiff images change on the storage the map service image doesn' refresh.
Any idea or support  is higly appreciated
thank you in advance!
Enrico
AsrujitSengupta
I think the only way to show the changes would be to restart the Map Service.
Scripting ArcGIS Server administration:
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
Example: Stop or start all services in folder
You could then use Window's Task Scheduler to run your python script.
Scheduling a Python script to run at prescribed times
