manually delete files in walarchive folder?
2789
12-02-2022 01:33 PM
TimHayes3
Our walarchive folder is getting too large at 469GB with all the log files. It is /arcgisportal/backup/walarchive.
I saw many posts here with the same issue. Can I just manually select and delete the files in this folder? will deleting these files this way cause problems with Portal?
I know you can use the webgisdr tool to do this, but I am wondering I can just delete them manually.
Tags (1)
ChristopherPawlyszyn
The files contained in that folder can be removed with the exception of the latest file (which is likely still being written-to). There was a database setting introduced at 10.9 to prevent the build-up of the write-ahead logs when not regularly using the WebGISDR tool, as well as a 'backup' mode that will not remove the cap on the log build-up.
https://developers.arcgis.com/rest/enterprise-administration/portal/database-settings.htm
-- Chris Pawlyszyn
