LINUX - Export Web Map Task PDF missing fonts
1439
02-01-2013 12:01 AM
Yann-EricBoyeau
I wanted to use printing service included with AGS 10.1 (SP1 on linux) to export map layout to PDF, I used standard ESRI templates for printing. The problem is output PDF file does not display Title and other layout text with the right font. The PDF property shows only ESRIAMFMElectric as included font which makes the pdf rather unreadable...
Labels/annos display well on the map dataframe (fonts are ok in the mapservice)
Did I miss something during the installation ? Should I put some windows fonts somewhere on the server for PDF export ?
Thank you
Yann-EricBoyeau
If you encounter the same problem, you have to copy windows .ttf fonts to /usr/share/fonts.
PDF now embed correct fonts.
Hope this help.
Yann-EricBoyeau
Hope this help.
Yann-EricBoyeau
In fact you also have to copy fonts to /server/bin/wine/share/wine/fonts ....
YvanBérard
Which Linux distribution are you using?
