LDAP Authentication Err: Failed to compute the privilege for the user. socket closed
12846
18
03-08-2013 04:23 AM
WillWhite1
Hi All
I'm wondering if anyone has thoughts on an issue I am having with ArcGIS Server 10.1 SP1.
I am managing users via an LDAP server. If I am accessing mapservices or indeed Manager/Admin Directory from a browser, following after a period of inactivity (2 hours I think) I am unable to re-authenticate. I get a message saying that the user doesn't have permission to access. I need to clear the browser cache, or re-open the browser/clear cache in order to be able to re-authenticate.
In the server logs I am getting:
"Failed to compute the privilege for the user '<user>'. <ldapserver>:<port>; socket closed"
I dont think there are any firewalls between my ArcGIS Server and the LDAP server.
I am using a webadaptor, with web authentication.
Any thoughts on how to either extend this time out or remove it all together?
Thanks in advance
Will
BubbaHey
Does the username contain a comma or other non-standard character? IF so, there is a bug on this, remove the character
WillWhite1
Thanks for your suggestion: It contains a couple of hyphens: ie a bit like this "abcde-f-ghi". Is this considered a non-standard charater?
BubbaHey
That should be fine.  Did you find a resolution?
JustinRodriguez
I think this is just saying that the user isn't found. First, does windows authentication work at the GIS Tier? Thanks-
WillWhite1
Thanks for your comments. I've not tried GIS Tier Authentication - would this model support Windows Authentication?
I'm investigating increasing the TCP timeout to see if this helps.
JustinRodriguez
Hello again,
No GIS Tier does not support the Windows Authentication, but you can use Windows to Authenticate. It would be a way to tell if the issue is on the server side or the web tier side. Thanks-
Justin
BubbaHey
I agree with Justin, try GIS. The only advantage (really) with Web Tier is single sign-on. Problem is it limits you, and I've seen problems publishing using Web tier.
NathanSommers
Good Morning,
I too have this same issue and I was wondering if you have found a solution to this problem.  In my instance I have found that the user group the user is a member of has lost all privileges for a specific service.  Once I go into ArcGIS Manager and restore the permissions for that user group all is well.  I do not however have any idea as to why the permissions get removed in the first place.  Any thoughts would be greatly appreciated.
Ian
JamesCameron1
I too am having this issue.....
We have a large AD with a large number of groups.... I wonder if it is a Kerberos token size issue......
This issue sound kind of like it http://support.esri.com/en/bugs/nimbus/TklNMDg2ODA3
Apart from I am using 10.2 so it should be resolved....
Had the same issue on upgrade and fresh install (on a new OS).....
