I'm trying to publish from our public ArcGIS Server 10.3 a map service in KML format with a simple point layer and map legend.
When i load the kml with GE or other KML/KMZ client i don't see any legend..
I followed the tutorial preparing an mxd wit a layout view with the map legend object:
Authoring maps for publishing as KML—Documentation (10.3 and 10.3.1) | ArcGIS for Server
Here a link to an example of out services:
energia/impianti_biogas (MapServer)
Any suggestion?
Thank you
Best
Ok, I flipped some settings on the server - I can get my KML to render. I tried yours again and see it:
I can get the legend to render with the map service:
KML layers should be supported... I'm still not sure why it wouldn't show for the KML. I started debugging the legend.js API file and didn't hit key spots that would construct the legend, but there wasn't a clear, obvious reason why. Perhaps it's a bug in the API? Are there any examples showing this working? I couldn't find one...
I tried pulling the kmz for review - unfortunately, I was unable to display even the kml using the ArcGIS JSAPI - here's the kml layer:
<?xml version="1.0" encoding="UTF-8"?> <kml xmlns:atom="http://www.w3.org/2005/Atom" xmlns="http://www.opengis.net/kml/2.2"> <NetworkLink> <open>1</open> <name>energia/impianti_biogas</name> <LookAt> <longitude>8.108852411473544</longitude> <latitude>45.22470127132088</latitude> <range>144615.2385434366</range> </LookAt> <Region> <LatLonBox> <north>45.61570041822</north> <south>44.32799635241058</south> <east>8.883711491697333</east> <west>7.338359921523349</west> </LatLonBox> <Lod> <minLodPixels>128</minLodPixels> <maxLodPixels>-1</maxLodPixels> </Lod> </Region> <Link> <viewRefreshMode>onStop</viewRefreshMode> <viewRefreshTime>2</viewRefreshTime> <href>http://webgis.arpa.piemonte.it/ags101free/rest/services/energia/impianti_biogas/MapServer/export</href> <viewFormat> f=kmz&bboxSR=4326&imageSR=4326&format=png24&transparent=true&bbox=[bboxWest],[bboxSouth],[bboxEast],[bboxNorth]&size=[horizPixels],[vertPixels]& </viewFormat> </Link> </NetworkLink> </kml>
I tried pulling some of my own map services this way and received something similar... I wonder if we need to flip a flag on the server...
Yes I use either the raster either the vector KML format generated by rest interface from here:
Generate KML (energia/impianti_biogas) /external-link.jspa?url=http://webgis.arpa.piemonte.it/ags101free/rest/services/energia/impianti_biogas/MapServer
I can't see any legend for both.
Just curious, are you using the following URL to access the service?
http://webgis.arpa.piemonte.it/ags101free/rest/services/energia/impianti_biogas/MapServer/kml/mapImage.kmz
Updated - I grabbed the wrong link before!
