issues loading data in map widgets after upgrading to 11.3 from 11.1 in some applications
999
08-16-2024 03:07 PM
paleo999
Team,
We are in the process of upgrading our enterprise portals from 11.3 to 11.1.  Currently the stage environment has been upgraded.  While everything looks good initially, I have noticed a few issues that are occuring with the map widgets only on certain map apps.  When I try opening Experience Builder and adding a map widget, I get the pending data screen--see attached.  This also occurs or the InstaApps, but not the dashboards.  I also don't have this problem when I open individual maps in the map viewer.
In our current prod environment everything works and I have been able to add map widgets successfully for both the Dashboard and the InstaApps Applications.
Yes, I did clear my cache on my browser.  Any advice would be very helpful, thanks!
BStephenson
Hi there - we are seeing similar problems. Did you find a resolution to this after your 11.3 upgrade? Thanks for any info you can share.
