Issue while opening ports for ArcGIS Server on firewall
3313
01-08-2021 01:51 AM
AYUSHYADAV
We are facing issues while installing the ArcGIS Server on Windows VM. We are following ArcGIS Server 10.8.x system requirements documents https://enterprise.arcgis.com/en/system-requirements/latest/windows/arcgis-server-system-requirement...
While opening given ports on firewall settings (inbound rules) the ports didn't get open. And when we install the ArcGIS Server without opening the ports on the firewall the ports automatically get open. We have verified the ports after the ArcGIS Server installation using telnet on command prompt.
How to open the ports before installing the ArcGIS Server as mentioned in the document?
JoshuaBixby
MVP Esteemed Contributor
Are you stating the ArcGIS Server installer is automatically configuring the firewall ports for you?  If so, why do you need to open them ahead of time if the installer is doing it automatically?
SuryaKant1
Hello Joshua,
I have the same problem with GeoEvent Server. After installation of GeoEvent Server it is saying that server is waiting for Zookeeper. I think GeoEvent Server is waiting for some port. Please suggest.
Regards,
Surya
AYUSHYADAV
ArcGIS Server installer automatically configuring the HTTP and HTTPS ports only not all the ports like ports which are used for intermachine communications. So how we can open these ports?
JoshuaBixby
Refer to your security client documentation.  Esri's installers automatically configure a couple ports because those ports need to be open for any deployment, but Esri doesn't automatically open all potential ports for every deployment.  For example, opening up inter-machine communication ports for a single-machine deployment would be unnecessary.  Since Esri doesn't know how the user will deploy the software, they provide all the ports that need to be open in their documentation, and the user can configure the local security client to meet their needs.
JonEmch
For reference: Ports used by base ArcGIS Enterprise components
Keep on keeping on!
