Is there any way to publish a service with two data sources on a single layer?
717
02-14-2019 04:56 AM
FabianoScardua
The problem is: How to display a different geometry data according the scale? The problem is about display a distinct geometry type not about the symbology of the layer.
Is there any way to do this?
TanuHoque
No. A feature layer can be of only one geometry type. You can't have a feature layer showing multiple types of geometry such as polygons and polylines or points.
what is the exact use case that you are trying to solve?
FabianoScardua
I'd like to show a different geometry on a different scale in an application. But I would not want to do this within the application source.
It's like changing a symbology on a different scale, but using a scale instead.
