input output parameters
3421
07-21-2015 09:32 PM
SyedMasood_Khadri
hi
I am trying to publish geoprocessing service with result map service to create buffer by using python script tool.
I have defined following inut output for python script tool.
distance: linear unit
outfc: feature class
It works fine when i run this tool in arcgis desktop 10.1 and creates and dispaly buffer in arcgis.
It fails when i publish as geoprocessing service with result map service. What should be the input output parameters ?
Thanks in advance...
SyedMasood_Khadri
this is resolved, i provided output a default value.
