I need help !!
940
06-06-2012 04:48 AM
NOELROSALES
I�??ve opened several layers under the table of contents in ArcMap, but cannot see all of them at the same time.  I can zoom to a state of Maryland layer and see it in the workspace. However, the other layers (roads, hydrology, census blocks) in my table of contents are invisible.  Zooming to one of the �??invisible�?� layers reveals it and all the other previously invisible layers. It was frustrating, so I decided to move on to my next planned task, creating a new shapefile in ArcCatalog, dragging it over to the table of contents in ArcMap, launching the Editor tool and digitizing (drawing) the feature. I was able to create the shapefile and successfully move it to the ArcMap table of contents. However, I cannot edit it!! It�??s sitting in the table of contents but NOT listed as one of the files available for editing in the Editor window.  So I gave up and decided to clip all the major roads to just those within the state of Maryland so I�??d feel I�??d accomplished something!  OMG, I can�??t even clip!  In fact NONE of the common geoprocessing tools work.
All of the above is caused by the same problem or omission, occurring TWICE -- Your job is to respond in the forum to  �??talk him down�?� and help him understand what is wrong and explain how to correct the two instances of the same problem and get some work done before the sun goes down.
JakeSkinner
Esri Esteemed Contributor
This sounds like a projection issue.  One or more of your shapefiles/feature classes are in the wrong projection.  I would add some reference data to your ArcMap document that you know is in the correct projection.  You can find such data at:
C:\Program Files (x86)\ArcGIS\Desktop10\Reference Systems
I would recommend adding the usstpln83 shapefile.  See which of your shapefiles align correctly in the state of maryland.
Try creating a new editing template:
1.  On the Create Features editing window, click 'Organize Templates' at the top
2.  Click New Template
3.  Select any layers that are not appearing in the Create Feature editing window
What is the error you are receiving when you try and execute the geoprocessing tool?
