I cant use geoevent tools
925
08-02-2020 03:52 PM
HadiGhayoomi_Mohammadi
I go to https://localhost:6443/arcgis/manager/index.html
to have access to ArcGIS server. then nowhere I cant find anything to add and work with GeoEvent. could you please help me understand how can I use Geoevent
I also tried to follow this to login
Log in to GeoEvent Manager—ArcGIS Enterprise | Documentation for ArcGIS Enterprise
but it says
This site can’t be reached
gisserver.domain.com refused to connect.
What is the problem???
ShaneMiles
Hi Hadi Ghayoomi Mohammadi‌,
So you replaced your localhost with gisserver.domain.com ? I would also ensure you have configured IIS on the server machine to enable https 443 and bind the server certificate. See Enable HTTPS on your web server—ArcGIS Enterprise | Documentation for ArcGIS Enterprise for steps on how to do this. I would also check your internet settings to ensure the site is within your organisations trusted sites. Lastly check your servers services to ensure the geoevent server is running. Hope this helps.
Shane
