HTTP request blocked
9757
10
03-24-2015 07:47 AM
mpboyle
Honored Contributor
We have recently migrated to a new ArcGIS Server which is configured to use https.  Upon migrating our apps over, some of them no longer work because the app is being loaded over https, but certain css files or js files are being requested over http, and thus are being blocked.  Attached is a screenshot of the developer tools window when trying to load one of our apps.
This particular app uses the Esri Story Map Countdown app template.
Can this be easily fixed or is this something our IT needs to fix in order to allow certain values over http?
Thanks in advance!
mpboyle
Honored Contributor
Issue has been fixed.  Apparently there needed to be a Geometry service explicitly stated in the main.js file.  I also removed all explicit http calls to '//' in the index.html file.
