How to determine which map services are using a specific data store?
11052
12
06-22-2020 01:51 PM
DurhamGIS
We're trying to track down the map services that are using a specific data store.  It seems the closest I can get to that information is with the ArcGIS Data Store command utility's describedatastore (ArcGIS Data Store command utility reference—ArcGIS Data Store (Windows) Installation Guide | ArcGIS ...) command which is limited to the number of current feature layer connections and nothing more. Is it possible to get these details some other way?
DerrickWong
Hi Vish Apte
Ah yeah, the manifiest.json. Yeah, querying this via REST will definitely work.
Cheers Vish.
Regards,
Derrick
JonasPersson
Hi VishApte
My experience with the manifest is that you cannot find information on which mapserver layer id that correspond to which dataset. Also, the order of the datasets in the manifest does not correspond to the order of the layers in the map service, even for a simple service using a single database and no group layers.
Do you have a simple way to do this? The only way i've found is to download a complete service backup, extract it and the MSDs inside, then traverse the xml-files inside to connect the layer id with the correct dataset.
Thanks!
TrevorH_OPE
Hi @DurhamGIS sorry to revive an old thread but you should check out Qonda Reports. It does exactly what you are asking. https://getqonda.com/
