Hosted Feature Layer can't load
3830
05-11-2022 01:24 AM
StefanoSchiavini
Hi all,
I have a single server base deployment of ArcGIS Enterprise with a of Feature Layer (Hosted) Services that serve a dashboard, the DBMS is PostgreSQL.
The site where the dashboard is published is https://cartorafia.provincia.lodi.it/
After the update of the windows server 2016 I notice that all this services are no more responding. Two weeks ago i've update the SSL certificate.
I've check all the configuration but I can't find any issue.
I can validate the datastore both from server/manager and  https://server.domain.com:6443/arcgis/admin, but can't load FHL and their REST service and I can't publish any new feature hosted layer from ArcGIS PRO.
Obviously I restarted ArcGIS Server and ArcGIS Data Store services and restart also the server without result
This is the arcgisdatastore\logs\<MYSERVER>\database log:
2022-05-04 10:07:03 CEST: [127244]: [1-1] ERROR: relation "hsu_vxwl0.sde_logfiles" does not exist at character 29
2022-05-04 10:07:03 CEST: [127244]: [2-1] STATEMENT: SELECT logfile_data_id FROM hsu_vxwl0.SDE_logfiles LIMIT 0
2022-05-04 10:07:03 CEST: [127244]: [3-1] ERROR: relation "pg_temp_5.sde_logfiles" does not exist at character 29
2022-05-04 10:07:03 CEST: [127244]: [4-1] STATEMENT: SELECT logfile_data_id FROM pg_temp_5.SDE_logfiles LIMIT 0
2022-05-04 10:07:03 CEST: [127244]: [5-1] ERROR: relation "hsu_vxwl0.sde_logfiles" does not exist at character 29
2022-05-04 10:07:03 CEST: [127244]: [6-1] STATEMENT: SELECT logfile_data_id FROM hsu_vxwl0.SDE_logfiles LIMIT 0
2022-05-04 10:09:33 CEST: [10220]: [1-1] LOG: could not receive data from client: An existing connection was forcibly closed by the remote host.
2022-05-04 10:09:33 CEST: [126288]: [1-1] FATAL: no pg_hba.conf entry for host "::1", user "dsadmin", database "dsadmindb", SSL off
2022-05-04 10:09:33 CEST: [126288]: [2-1] DETAIL: Client IP address resolved to "LEONARDO2", forward lookup does not match.
2022-05-04 10:09:34 CEST: [18388]: [6-1] LOG: received fast shutdown request
2022-05-04 10:09:34 CEST: [18388]: [7-1] LOG: aborting any active transactions
2022-05-04 10:09:34 CEST: [17120]: [1-1] FATAL: terminating connection due to administrator command
2022-05-04 10:09:34 CEST: [18388]: [8-1] LOG: worker process: logical replication launcher (PID 20012) exited with exit code 1
2022-05-04 10:09:34 CEST: [10388]: [1-1] LOG: shutting down
2022-05-04 10:09:35 CEST: [118424]: [1-1] FATAL: the database system is shutting down
2022-05-04 10:09:36 CEST: [125416]: [1-1] FATAL: the database system is shutting down
2022-05-04 10:09:36 CEST: [125932]: [1-1] FATAL: the database system is shutting down
2022-05-04 10:09:36 CEST: [127184]: [1-1] FATAL: the database system is shutting down
2022-05-04 10:09:36 CEST: [18388]: [9-1] LOG: database system is shut down
2022-05-04 10:11:24 CEST: [26080]: [1-1] LOG: database system was shut down at 2022-05-04 10:09:34 CEST
2022-05-04 10:11:25 CEST: [24604]: [5-1] LOG: database system is ready to accept connections
2022-05-04 10:12:17 CEST: [25404]: [1-1] LOG: could not receive data from client: An existing connection was forcibly closed by the remote host.
2022-05-04 10:14:04 CEST: [40756]: [1-1] LOG: could not receive data from client: An existing connection was forcibly closed by the remote host.
2022-05-04 10:14:44 CEST: [33280]: [1-1] LOG: could not receive data from client: An existing connection was forcibly closed by the remote host.
2022-05-04 10:15:30 CEST: [50212]: [1-1] LOG: could not receive data from client: An existing connection was forcibly closed by the remote host.
2022-05-04 10:48:33 CEST: [36648]: [1-1] LOG: could not receive data from client: An existing connection was forcibly closed by the remote host.
2022-05-04 10:48:33 CEST: [21336]: [1-1] FATAL: no pg_hba.conf entry for host "::1", user "dsadmin", database "dsadmindb", SSL off
2022-05-04 10:48:33 CEST: [21336]: [2-1] DETAIL: Client IP address resolved to "LEONARDO2", forward lookup does not match.
2022-05-04 10:48:34 CEST: [24604]: [6-1] LOG: received fast shutdown request
2022-05-04 10:48:34 CEST: [24604]: [7-1] LOG: aborting any active transactions
2022-05-04 10:48:34 CEST: [21368]: [1-1] FATAL: terminating connection due to administrator command
2022-05-04 10:48:34 CEST: [24604]: [8-1] LOG: worker process: logical replication launcher (PID 22784) exited with exit code 1
2022-05-04 10:48:34 CEST: [24484]: [1-1] LOG: shutting down
2022-05-04 10:48:35 CEST: [30868]: [1-1] FATAL: the database system is shutting down
2022-05-04 10:48:36 CEST: [26992]: [1-1] FATAL: the database system is shutting down
2022-05-04 10:48:36 CEST: [21424]: [1-1] FATAL: the database system is shutting down
2022-05-04 10:48:36 CEST: [26016]: [1-1] FATAL: the database system is shutting down
2022-05-04 10:48:36 CEST: [24604]: [9-1] LOG: database system is shut down
2022-05-04 10:50:21 CEST: [42204]: [1-1] LOG: database system was shut down at 2022-05-04 10:48:34 CEST
2022-05-04 10:50:23 CEST: [127452]: [5-1] LOG: database system is ready to accept connections
2022-05-04 10:58:06 CEST: [107788]: [1-1] ERROR: relation "hsu_vxwl0.sde_logfiles" does not exist at character 29
2022-05-04 10:58:06 CEST: [107788]: [2-1] STATEMENT: SELECT logfile_data_id FROM hsu_vxwl0.SDE_logfiles LIMIT 0
2022-05-04 10:58:06 CEST: [107788]: [3-1] ERROR: relation "pg_temp_5.sde_logfiles" does not exist at character 29
2022-05-04 10:58:06 CEST: [107788]: [4-1] STATEMENT: SELECT logfile_data_id FROM pg_temp_5.SDE_logfiles LIMIT 0
2022-05-04 10:58:06 CEST: [107788]: [5-1] ERROR: relation "hsu_vxwl0.sde_logfiles" does not exist at character 29
2022-05-04 10:58:06 CEST: [107788]: [6-1] STATEMENT: SELECT logfile_data_id FROM hsu_vxwl0.SDE_logfiles LIMIT 0
2022-05-04 11:38:33 CEST: [33312]: [1-1] ERROR: canceling statement due to user request
2022-05-04 11:38:34 CEST: [127452]: [6-1] LOG: received fast shutdown request
2022-05-04 11:38:34 CEST: [127452]: [7-1] LOG: aborting any active transactions
2022-05-04 11:38:34 CEST: [62932]: [1-1] FATAL: terminating connection due to administrator command
2022-05-04 11:38:34 CEST: [43024]: [1-1] FATAL: terminating connection due to administrator command
2022-05-04 11:38:35 CEST: [127452]: [8-1] LOG: worker process: logical replication launcher (PID 33312) exited with exit code 1
2022-05-04 11:38:38 CEST: [118480]: [1-1] LOG: shutting down
2022-05-04 11:38:43 CEST: [127452]: [9-1] LOG: database system is shut down
Maybe someone has found a less drastic solution than reinstall all the Enterprise suite?
Thanks in advance
Stefano
Scott_Tansley
MVP Regular Contributor
Have you tried using the DescribeDatastore command line tool?  ArcGIS Data Store command utility reference—ArcGIS Enterprise | Documentation for ArcGIS Enterprise
You said you've updated the SSL certs, is that in the web adaptor/arcgis server?  If the latter than you need to run this:
I've also seen issues like this when the the server license has expired and the data store needs to pick up the new license to keep running:
Obviously, it could be many things, but they would be the go to ones if you haven't used them already.
Scott Tansley
https://www.linkedin.com/in/scotttansley/
StefanoSchiavini
thank you @Scott_Tansley ,
I've already done the first two advice.
Now I try to lunch the updatelicense utility, but the server/manager show that the license never expire.
Stefano 
Scott_Tansley
This may be a red-herring, but the owing system URL on the relational datastore is:
https://LEONARDO2/server
on the tile cache it's:
https://leonardo2.localdomain.com:6443/arcgis/admin
I'm not convinced that the relational owning URL is correct and may need reconfiguring?  I typically always use fully qualified domain names, and would have expected that here.  Given that the context 'server' suggests use of a web adaptor, I wonder if  your new SSL cert supports leonardo2?  It may just be the FQDN?  Hard to tell without seeing it, but I'd have anticipated a similar entry to the tile-cache?
Scott Tansley
JakeNeedle
Hi Stefano,
Did you ever get a solution to this issue? We are facing the same situation.
Jake
