Getting an??? 001270 error : Consolidating the data failed.??? while publishing @ AGS101
1011
11-04-2012 04:00 AM
SunilPalkar
Hello All,
I am getting an error "001270 error".
I am inserting table for sql-server database and joining few records to polygon layer
also I have lat,Lon data in few tables so I am displaying data using "Display x,y values" and publishing all data into arcgis server 10.1 (using ArcGIs Desktop 10.1)
While publishing I was getting above error..
also my database & folders are registered in ArcGIS Server (through ArcCatlog I did this)
I found following article which explain that it might  bug  . ..                                                        Link : http://support.esri.com/en/bugs/nimbus/TklNMDgzMjc5 ..but I am not sure..
So any help regarding this will be great..thanks in advance : )
TerryGiles
I am also receiving this error when trying to publish or save a service definition file.  I'm not sure what Esri's bug report means by a 'nested join' but I'm only joining a standalone table to a feature class, both of which reside in the same SDE instance, which is registered as a data store with Server.
Anyone have a workaround or fix?
Thanks, Terry
