Geocoder Compatibility from Pro 3.6 to Enterprise 11.5
986
12-04-2025 09:22 PM
DEWright_CA
Would Geocoders/Locators built with ArcGIS Pro 3.6 be fully compatible with Enterprise 11.5; or should I stick with building locators in 3.5.x for this?
Is there a list of functionality that is not backwards compatible?
Priya_Das
Hi @DEWright_CA,
Its recommended to use compatible version of ArcGIS Pro 3.5.x with ArcGIS Enterprise 11.5. You may encounter warnings or errors due to new or modified parameters that Enterprise 11.5 does not support.
https://pro.arcgis.com/en/pro-app/latest/help/analysis/geoprocessing/share-analysis/web-tool-compati...
