Hey All,
I've been attempting to get to know the REST API a little more, and I have found some odd issues with generating a token.
I seem to only be able to use the PSA account siteadmin to generate a token. I attempted to use portaladmin and another built in account, but I continually am met with "Invalid username or password", when I am quite sure that the case-sensitivity has been tested, along with the password correct.
Is it only possible to generate a token via ArcGIS Server accounts? I attempted to create a user through the Server security settings and it still did not work.
Enterprise 11.2, ArcGIS Server federated with ArcGIS Portal.
Any ideas?
Thanks in advance!
Cody
Solved! Go to Solution.
Hi @CodyPatterson there are a couple of steps involved here, if you are going to access a resource via REST api. One of the option is to create a user account with edit role (will need creator license in the portal), add that user to a group (you may have to create a group with shared update enabled so that all users in that group can edit feature layers shared with them) and then share the feature layer which you want to edit as an item to that group.
You can then use that user credentials to generate token like this:
https://yourportaldomain.com/portal/sharing/rest/generateToken
Since the gis server is federated, the authentication to the server will be handled by the portal
Hope this helps.
Thomas
Looks like I've found the issue, apparently I needed to use the referer URL in order to accomplish this, so setup the token through the portal/rest directory, and then use a portal login with the referer being the actual ArcGIS Server.
Thanks for the help @Thomas_Puthusserry, definitely pointed me in the right direction!
It would help if you provided a bit more information. It sounds like you are talking about an ArcGIS Enterprise deployment with portal and federated ArcGIS Servers (as opposed to stand-alone ArcGIS Server), correct? When an ArcGIS Server is federated with a portal, the authentication goes through the portal except for the built-in PSA account. The portal provides a token to use with the federated ArcGIS Server, you don't login directly to AGS with portal credentials. What REST calls specifically are you using?
Hey @JoshuaBixby
That is correct, Enterprise 11.2 with portal and federated servers. The REST call we are attempting to use would be the addFeatures POST request, a token would be required to use these services.
We have an application that we would like to move certain POST requests from pointing to a third-party vendor to instead point into ArcGIS Server to create the necessary points, lines, and polygons. I would like to not use the siteadmin credentials when performing these operations as that seems like a non-security conscious decision.
Hope that clears things up!
Cody
Hope this helps.
Thomas
Thank you for the response! It was very straightforward so I appreciate that, I attempted to create the token and use it in the same way I had before using a GET request, and it now states Invalid Token. I attempted this with IP Address and IP Address of this request's origin.
Cody
Hello @Thomas_Puthusserry ,
I have a question regarding the PrivatePortalURL configuration in an HA environment. I'm a bit confused about which format to use:
https://Internal-lb.domain:7443/arcgis
https://Internal-lb.domain:7443/portal
The confusion arises because I noticed a redirect occurring when the hosting server tries to access the portal to generate a token for the publishing process. This results in an "Invalid token" error being logged in the portal.
Also is there any property I should configure in the load balancer that might relate to this redirect?
If you use a token generated by the PSA does that work to edit on the layer? If so you may want to login in a different browser with the user credentials created and used to generate the token and check whether you can edit the feature layer in question.
Thank you for the quick response, I attempted with the Portal PSA and it remained the same, I attempted with the Server PSA as well and got Invalid Username or Password on the token generation, I assume due to it being a Server account not a Portal account. I was able to edit on both PSA and account tested, very unusual stuff!
Cody
