Filtering a map service according a value in a particular field,
2796
11-27-2014 10:44 PM
JamalNUMAN
Legendary Contributor
I have a layer that contains all Urban Master Plans (UMPs) for all municipalities across the country. This layer is published as a map service. Now, how can a municipality stick only its UMP in its web mapping application by filtering the map service according to a value in the “ZoneCommunityName” field?.
Thank you
Best
Jamal
Jamal Numan
AnthonyGiles
Honored Contributor
Jamal,
You do not mention what your are trying to put the layer into, but mapserivces support queries (like using a definition query in arcmap). See the help here:
ArcGIS REST API
example:
Query states
I think if your are wanting to do this in arcmap you have to add the layer as a feature service not a map service. On a feature service you can set up a normal definition query.
Regards
Anthony
JamalNUMAN
Many thanks Anthony for the input,
The destination of the map service of the UMPs is web mapping applications of municipalities. As all UMPs across the country are published in ONE map service (about 100,000 features), then Municipality A, for example, should be able to filter the entire service to obtain the UMP that corresponds to Municipality A only.
How filtering the UMPs service can affect only the one added to a particular mapping application? For example, I need to filter the UMPs service to obtain the UMP for municipality A and then other municipality should be able to filter the UMPs service to obtain the UMP for municipality B and so forth.
Is that possible?
Jamal Numan
