Failed to connect to database
4026
02-07-2013 05:30 PM
jamiehollingsworth
So after updating my license file i now get this error when trying to access my database.
Failed to connect to database. No arcgis server license file found. contact your admin.
i have tried creating a geodatabase using all of my connection info and i get an Error.
Error connecting to database as geodatabase admin.
I can connect to the database outside of arcgis.
arcgis server 10.1.1
windows server 2012
IIS 8
postgresql 9.1
everything was working prior to updating of license file
any thoughts
nicogis
Where have you this error ("No arcgis server license file found")?
jamiehollingsworth
so i fixed it
first i found this page
http://blogs.esri.com/esri/supportcenter/2012/08/09/how-to-get-an-authorization-file-or-keycodes-fil...
but i was not getting the update arcgis license box
then i found this
http://support.esri.com/en/knowledgebase/techarticles/detail/40597
i had to create a new connection with admin privileges.
problem solved
