Extract Data Geoprocessing Task delivers zip file but the features won't display
2200
05-10-2013 11:23 AM
KristenWobbe
Extract Data Geoprocessing Task delivers a zip file with a file GDB but the features won't display.
Running the Geoprocessing task from the REST page I do "get a .zip file" that appears to have data, but the features won't display.
When I create the geoprocessing service from the results in ArcMap 10.1, normally I would run this from the Geoportal Server 1.2.2 Download Tab web interface, but get the same result as when I run it from the REST page, everything appears to be great,
- but when I extract the data.gdb from the ZIP file and add the data to ArcMap,
- again everything appears to be fine and looks perfect in the TOC, except there are no features that will display.
- It appears there is data in the GDB sent in the zip file
Has anyone run into this issue, or have any helpful thoughts to share? :cool:
dancheng
Hey, it is normal, cuz the area of interest polygon is empty when you submit job in rest pages, so if you open that service in ArcServer insider of arcgis, and draw polygons on Arc Desktop, you would have the actually data in the zip file.
Hope it helps,
Dan
