Exclude related data from copying to server when publishing
548
12-10-2024 12:49 PM
MaximeDemers
I am now using Enterprise 10.9.1 with Pro 2.9.14.
I have noticed a change with the previous version I used, Enterprise 10.6.1 with Pro 2.7, when data are copied to the server when publishing a service.
Since the upgrade, it seems all the related data to any layer in an aprx is also copied to the server even if they are not included in the map.
In my situation, this is not a good thing because a particular layer is related to 6 other feature classes that have attachments enabled, resulting in 3.6 GB being copied to the server instead of 80 MB before.
Is there a way to prevent Pro from copying the unwanted related data when publishing?
Thank you
P.S.: I am also using script for the publication, so if there is a possibility by editing the sddraft I am ok with it.
