Error performing insert operation on Branch Version enabled UNM services
504
11-19-2025 05:40 AM
RaghavGupta
Hi All
I have published the feature services from utility network . These services are branch versioned. I have changed the version to branch version from default in ArcGIS Pro.
I am able to update the existing data via services when doing it from ArcGIS Pro. However, while doing the add operation it is failing and not able to add any feature. The error message says Error performing operation. Can you please help me here.
Raghav
RussellBrennan
Hi @RaghavGupta
When you mention that you are using the add operation, are you doing this via code, from the REST endpoint page? Can you share an example of the payload you are sending? Can you try using the ApplyEdits operation to see if that works?
