Error 10030, Please help
863
08-08-2012 11:27 PM
ReziKenia
When i Analyze my map to publish the warning appeared:
"10030 Layer's data source is ArcSDE not accessed via a direct connection <Data Base> Layer Layers"
i use
oracle11gv2
ArcSDE
Arcgis server 10.1
Arcgis Desctop 10.1
I cannot make direct connection to oracle database from ArcCatalog. I try this syntax's
"sde : oracle11g:/;ORACLE_SID=<SQL_Net_alias>" but it does't work .....
BubbaHey
This is out of my knowledge area, but see:
10030: Layer's data source is ArcSDE not accessed via a direct connection
http://resources.arcgis.com/en/help/main/10.1/index.html#//00sq0000002p000000
