ERROR 001272 when publishing a service with related tables
4872
05-15-2016 07:48 AM
ShawnHibbs
I am having a problem when trying to publish a feature service with a related table in it. It works fine without the related table so I know it is specific to that. I have registered the table as versioned and set up a relationship class between the layer and the table. I do not receive any errors or warnings when analyzing the map before publishing. At this point I can't think of anything else that could be the issue. Does anyone have an idea of what might be causing this error?
MichaelRobb
Honored Contributor
Some pertinent information such as which version of ArcMap  / ArcGIS Server is being used.
Try not versioning the base table, what are the results?
ShawnHibbs
I don't know how, but it is working now.
