ERROR 001270: Consolidating the Data Failed.
3178
07-10-2012 05:27 AM
ShaningYu
Honored Contributor
Re-published the mxd using the same procedure but with checking off some attributes.  Did not see the error this time.
ShaningYu
Honored Contributor
The problem was gone but it is unclear for the reason.
stephensontag
Were you publishing a geoprocessing service?  I am getting this error and haven't been able to get around it.  I'm using Oracle/SDE.
ShaningYu
Honored Contributor
KeG
I'm seeing this also, while publishing a gp tool. I'm not trying to move any data.
