ERR_HTTP2_PROTOCOL ERROR
768
07-15-2025 09:08 PM
MarcoPoetsch
Hi all,
I’m encountering an intermittent issue when navigating a web map that uses ArcGIS Server feature services on my Enterprise 11.1 environment.
As I pan or zoom, I sometimes get the following error in the browser console:
GET <service URL> net::ERR_HTTP2_PROTOCOL_ERROR
dojo.js:411
 GET https://maps....../server/rest/services/..../..../Featur…tPdVQdKKKKGMufrIgeAMi9HzlcY9soAHQqv4EWldu2-GBfaizl4PLLOZDN33YynLok4DSTiU8. net::ERR_HTTP2_PROTOCOL_ERROR
(anonymous)	@	dojo.js:411
d	@	dojo.js:35
q	@	dojo.js:40
(anonymous)	@	dojo.js:40
D	@	dojo.js:407
(anonymous)	@	dojo.js:416
d	@	dojo.js:35
q	@	dojo.js:40
Promise.then
d	@	dojo.js:36
q	@	dojo.js:40
J	@	dojo.js:415
(anonymous)	@	dojo.js:401
d	@	dojo.js:35
q	@	dojo.js:40
Promise.then
d	@	dojo.js:36
q	@	dojo.js:40
m	@	dojo.js:399
(anonymous)	@	dojo.js:397
d	@	dojo.js:35
q	@	dojo.js:40
Promise.then
d	@	dojo.js:36
q	@	dojo.js:40
request	@	dojo.js:398
t._onInvokeMessage	@	dojo.js:1732
t._onMessage	@	dojo.js:1732
Some layers fail to load immediately but eventually appear after a delay. Occasionally, none of the services load at all — for any users — and everything times out. After about a minute, things recover and start working normally again. This seems to happen at random, and we haven’t made any recent changes to the services or server configuration. Has anyone experienced similar issues with ArcGIS Server and HTTP/2? Could this be related to server load, proxy configuration, or something else?
Would appreciate any pointers for troubleshooting.
Thanks!
CodyPatterson
MVP Regular Contributor
Hey @MarcoPoetsch
From the item you linked, it looks like an error within the console showing which files ended up failing or similar. Can you send a screenshot of the console and network page to see if any requests failed? Here's a couple additional places I'd check:
  1. Check the server manager logs, see if anything at that time ended up freaking out.
  2. Check any proxy logs, they may show a broken connection or similar
  3. If using ArcGIS Monitor, verify that everything is showing normal around this time, and if not, check to see if resources are near maxed
  4. If there is no Monitor, check Linux resource usage or Windows Task Manager to view the usage
  5. Record what you're doing when it does this, maybe it isn't random and tied to something underlying
These are the things I'd try, hope it help!
Cody
MaximilianFeuerer
Hi @MarcoPoetsch,
Have you tried using Firefox for your workflow? Perhaps there is a connection to BUG-000168562 for Portal for ArcGIS
Best,
Maximilian
