Enable the stream service on Web Adaptor port 6143 for external machines to access real-time data feeds
1042
12-14-2023 08:54 AM
abhishek_choudhary
I've set up the GeoEvent service with a Stream Service as the output connector. I've observed that the WebSocket URL for the stream service utilizes port 6143, which is the GeoEvent port. However, at present, this port is not accessible externally from the server. Additionally, we've configured the Web Adaptor for the ArcGIS Server. Is there a method to subscribe to the Stream Service from outside the server using only the ArcGIS Server URL to view the stream service data or just expose the stream service outside.
Thanks & Regards,
Abhishek Kumar Choudhary
JakeSkinner
Esri Esteemed Contributor
