Elevation Server Object Extension - Release for 10.1
1089
04-09-2013 12:02 PM
KevinMacLeod1
Hi all,
Does anyone know the estimated time of release for the Elevation Server Object Extension for ArcGIS Server 10.1?
The ESRI developer posted "soon" here - http://blogs.esri.com/esri/apl/2010/10/07/elevation-server-object-extension/
We would like to deploy this for a 10.1 server. Looks like a great piece of software.
nicogis
it has already been released http://www.arcgis.com/home/item.html?id=60bf17f2d59441839135adc25654a7d9
if you need also other operations on the surface can also see this soe ( http://www.arcgis.com/home/item.html?id=1c96538fa81948efb5a2436532964def )
KevinMacLeod1
Thank you Domenico. Also, your Surface utility is fantastic! Thank you again.
