Does the type of “tile format” of a cached service affect the performance?
I’m wondering if the type of “tile format” of a cached service affect its performance when consumed.
Thank you
Best
Jamal
Hi again Jamal,
PNG format supports transparency and is a lossless format. I would assume JPEGs are prefered for higher perfomance due to the compressed file size and non transparency.
This really depends on the differences between png and jpeg handling by arcgis server from the bundle file (.bundle), which I am unfamiliar with.
Cache perfomance can be improved by tuning the disk sector size.
Hope this helps,
Al
Thank you for the useful input Aled Jon
Could you please elaborate a bit more regarding tuning the disk sector size and how this can enhance the performance of the services when consumed?
No problem Jamal.
for example if your disk sector size is 4kb and you have three 5kb images, you are wasting 1kb of space per 3 sectors.
It's always important to consider this when building a cache.
Retrival of the cache files can be affected by fine resolution of data in disk sectors which would affect perfomance.
Many thanks Aled for the help. This is very useful
Best
Jamal
I’m back to the same enquiry.
What is the best “image format” for imagery caching that brings optimum cache tiles in terms of quality (high degree of color variation) and performance
https://www.arcgis.com/home/item.html?id=a269d03aa1c840638680e2902dadecac#!
MXD PerfStat is what ESRI Professional Services would use. At least to test web server loads, display performance, and image display refresh times.
Thanks Jay for the input
